Converting Rear Window To Hinged Opening Type
12 replies to this topic
#1 brownspeed
brownspeed
  • 451 posts
Posted 20 September 2014 - 08:35 AM
my RSP was originally fitted with hinged type rear windows. at some point she's been modded to "fixed" type.
I'm considering changing them back....
1) is the glass different between the 2 types.
2) is it worth it? .there not much originality left in the car so its not really important; more of a whim really.
any advice?
#2 petey81
petey81
  • 1,341 posts
Posted 20 September 2014 - 08:44 AM
Different glass and seals. Not hard to do.
Edited by petey81, 20 September 2014 - 08:44 AM.
#3 exuptoy
exuptoy
  • 674 posts
Posted 20 September 2014 - 08:45 AM
I'd leave it. They're usually the cause for the rust around the bottom edge of the frame when they drop.
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 20 September 2014 - 10:13 AM
As above the metal surround around the edge of the opening type tends to rub against the bodywork and also trap rain water at the bottom creating a corrosion point, which is why many people convert to the non opening type.
#5 brownspeed
brownspeed
  • 451 posts
Posted 20 September 2014 - 12:42 PM
SOLD!
thanks guys, i'll leave it. its not like I've run out of jobs to do!!
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 September 2014 - 06:20 PM
I like rear opening windows, as you can leave them open without having wind in your face.
#7 ShaunaFTW
ShaunaFTW
  • 594 posts
  • Local Club: TurboMinis
Posted 20 September 2014 - 06:56 PM
I'm so glad I have opening windows when it's roasting outside although you could just crack the door windows, I'm not sure what it's like for people sitting in the back though. I can't tell they are open while I'm driving other than the noise!
#8 brownspeed
brownspeed
  • 451 posts
Posted 21 September 2014 - 12:09 PM
to be honest there is virtually no gap between the seat backs and the rear seat anyway on mine; wind noise wouldn't be an issue; rear passengers would be more concerned with the lack of blood flow to their ankles.
#9 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 21 September 2014 - 02:17 PM
I have one mini with opening rears, and the other with the sealed type. I'm not doubting the ventilation benefits of rear openers, they're better for rear passengers and also highly preferable in terms of looks/aesthetics too. It's widely recognised that they do encourage corrosion though, which in classic mini ownership terms, is usually the primary thing to avoid. The other issue is security, in that the opening type are much more vulnerable to break ins than the sealed type are.
#10 MrIan
MrIan
  • 125 posts
Posted 21 September 2014 - 03:37 PM
Openers for me, if they touch the body when closed they need adjusting a bit.
#11 Midas Mk1
Midas Mk1
  • 5,788 posts
  • Local Club: S.U.N.M.C
Posted 21 September 2014 - 03:57 PM
Well worth it!
#12 dolph
dolph
  • 50 posts
Posted 21 September 2014 - 07:42 PM
Mine got broken into by pry baring the rear opening windows. Wish they'd just used a screwdriver. Also the one side had a lot of corrosion where water was sitting on the waste rail. I'm not a fan of opening rears
#13 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 22 September 2014 - 09:08 PM
Why'd they bother with a pry bar? There's easier ways to get into a mini (unfortunately).
