Hi
Just wondered how you lot keep your wheel arch trims (rubber) between the body and arch. Mine falls out at the ends. Was thinking a blob of super glue maybe?
Josh
Arch Rubber Trim
jt19
, Sep 20 2014 07:49 PM
6 replies to this topic
Posted 20 September 2014 - 07:49 PM
Posted 20 September 2014 - 08:06 PM
Dont use it? I think it looks a lot cleaner and neater without it. I wouldnt superglue anything to the paintwork though.
Posted 20 September 2014 - 08:13 PM
I'd super glue it to the arch. And only a small blob.
Would it not chaff against the body without the rubber?
It's sports pack arches if that helps.
Posted 21 September 2014 - 05:35 PM
It should be fine without as the arch will move with the body if its secure.
Posted 21 September 2014 - 05:41 PM
Neoprene adhesive (evostik type). That can be cleaned off if it seeps out. Superglue is impossible to remove.
Posted 27 September 2014 - 07:04 PM
What rubber trim are you using?? The 'P' type or the 'U' type??
My mate had this trouble with the p type so he bought the u type and it's so much better
Posted 28 September 2014 - 01:16 PM
I've sorted it now thanks mate.think it's the u type.
