Finally taxed and tested all ok but just found. Fuel leak the feed into the fuel pump is leaking does any one know if this is pressurised as was coming out pretty fast even after I stopped the engine I got pliers onto clamp and pushed fuel line in further but still leaking can any advise what size fuel pipe I would need and jubilee clips to suit
Thanks in advance nelo
Fuel Pump Leaking
nelo36
, Sep 20 2014 09:27 PM
3 replies to this topic
Posted 20 September 2014 - 09:27 PM
Posted 20 September 2014 - 09:31 PM
Its 1/4 bore standard and jubilee clips are no good they dont do up circular on small O/D applications, you need proper fuel pipe clips, not sure from memory what size mine are? bit late to go out in the workshop.
Posted 20 September 2014 - 09:35 PM
Cheers for the info I'll go to spares place near me and get some tomorow
Thanks nelo
Thanks nelo
Posted 20 September 2014 - 10:03 PM
Dont get the white clear stuff it goes hard quick, and some is so tight it causes the stake up outlets to move and leak
