Quaif Diff
9 replies to this topic
#1 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 22 September 2014 - 02:46 PM
Hey guys,
Having a problem with the way my mini is driving and am after some help.  When I put the power down my car pulls me all over the road, sometimes left sometimes right, depends on what the road is like.  It almost feels like I have an LSD the way its snatching and pulling me over the road.  Has anyone else got a quaif diff that does this?
Lofty
#2 The Principal
The Principal
  • 763 posts
Posted 22 September 2014 - 02:53 PM
I use a Quaiffe diff and mine doesnt respond like that, what wheels and tyres are you running?
#3 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 22 September 2014 - 03:05 PM
12 x 6 with A539
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 22 September 2014 - 03:13 PM
What Quaiffe diff is it? I have used an ATB with no problems in the past (and have a new one sat on the shelf as we speak).
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 22 September 2014 - 03:23 PM
No LSD should drag the car all over the road.  Get your alignment done and check for play in wheel bearings and ball joints.
#6 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 22 September 2014 - 03:39 PM
its a quaif ATB.  Are you all using them with pretty standard engines? as mine is quite highly tuned so would that be causing me the issues? or should the quaif deal with the higher output?
#7 Da11yn
Da11yn
  • 72 posts
Posted 22 September 2014 - 05:20 PM
I have a quaiffe atb taking reasonable power and when I first put it in it pulled all over the place going from on and off power. Turned out the tie rod pushes had worn badly replace them and was back to being unnoticeable which was why I went for the atb over a plate or cam LSD as i do a lot of road miles with it. And that's with 13 x7s which exasivate and suspension play.
#8 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 22 September 2014 - 05:38 PM
ok cheers mate,  I rebuilt the car from scratch, so all the components are brand new, the only thing I have done differently is put coilover suspension on, but that should make a difference, i'll go all around the car again and give it a good old tighten and see if that helps
#9 jt19
jt19
  • 745 posts
Posted 22 September 2014 - 07:09 PM
Just out of interest does the atb reduce torque steer?
#10 mini13
mini13
  • 3,811 posts
Posted 23 September 2014 - 11:37 AM
LSD's will highlight any suspension problems,
if you've got anything thats  got play in it, or mal adjusted it will likely cause issues.
corner weights are another good one, as the rear of the car squats, if one side softer and it squats lopsided then it will loose traction on on front wheel sooner, and pull one way.
also big offset wheels are bad for this as they give the steering less leverage.
