Anti Seize Compound Of The Crank Taper?
Posted 25 September 2014 - 05:49 PM
I've lapped the two together and cleaned both areas thoroughly, but I'm wondering if I can add a thin smear of copper grease / WD40 / anti seize lube to help get the flywheel and clutch off when needed.
Posted 25 September 2014 - 06:00 PM
ive never heard of it, no one in historic mini racing
ever mentioned doing this, I would imagine the flywheel would come loose
but lets see what the experts say
Posted 25 September 2014 - 06:19 PM
doesn't it rely on the friction? normally small angle tapers like that are used to drive things such as a morse taper on drills etc. someone must have tried it though?
Posted 25 September 2014 - 06:40 PM
If you've lapped the crank on properly, then there will not be an issue removing it in the future....
If you do have trouble then you should get one of these....
http://www.guess-wor...play.htm?id=501
Ok....ok... that was a cheap plug
Posted 25 September 2014 - 06:47 PM
John that looks a good bit of kit :) i know of people who have shattered the plate of the puller, and stripped threads too
Posted 25 September 2014 - 07:04 PM
I like the look of that. I have a feeling I will be ordering one later as I think I need to re cut the threads in the flywheel center on mine....
Posted 25 September 2014 - 07:17 PM
Looks a good bit of kit.
Hopefully I've lapped the flywheel in enough?
If not I'll have to use my old centre boss as my new flywheel is attached to the clutch, would this be okay if required?
Cheers again
Posted 25 September 2014 - 08:02 PM
Posted 25 September 2014 - 09:38 PM
Ah... you'll be needing one of these too then
http://www.guess-wor...play.htm?id=488
Wow.... Two shameless plugs in one post....
Posted 25 September 2014 - 09:56 PM
Maybe not as I don't think the holes were correct. I only noticed after fitting the flywheel that something was amiss. And that was 20 some years back.
But to be honest I am liking your products.
The main thing about that puller is the fine thread compared to the others.
