I have also posted this on the Autosport Labs forum
Posted 27 September 2014 - 09:24 AM
Posted 27 September 2014 - 09:31 AM
I have 1 1380 map and all the Aldon 123 dizzy curves.
https://drive.google...UEU&usp=sharing
Please bear in mind these will not be perfect for your setup, and you use them at your own risk. These may get you running but I advise getting to a rolling road ASAP to fine tune it.
Posted 27 September 2014 - 03:36 PM
Posted 27 September 2014 - 07:15 PM
No problem.
They will, but no idea how to find out which one is best suited.
To install a map, click on one of the maps in my link, you should see a download option. Download it and move it from your downloads folder to a megajolt maps folder (if you don't have one I'd create one) Then open the megajolt software (if you don't have it yet download it from the autosport labs website). Plug your laptop/computer into the megajolt box using a serial - USB converter. power up the megajolt by turning on the ignition if it's in the car, or a 9V battery will be enough to power it on the bench. Any errors can be troubleshooted using the guides on the autosport labs website. once connected open the map you want to use. Then click 'Write to flash' button, which looks like a microchip, that'll save the map to the megajolt unit.
That's it
