High Compression On One Cylinder?
engine
11 replies to this topic
#1 Lsurt95
Lsurt95
  • 112 posts
  • Local Club: North East Mini Club
Posted 27 September 2014 - 02:32 PM
hi
Recently my engine has been running quite poor. I took the Spark plugs out to discover number 4 was damp and almost oily. I then decided to do a compression test and come across an unusual reading (these were done while cold)
cylinder 4- 225 psi
cylinder 3- 175 psi
cylinder 2- 175 psi
cylinder 1- 175psi
has anyone got a possible reason for this?
Liam
#2 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 27 September 2014 - 03:15 PM
I've read in one of the manuals, forget which one, that it could be carbon build up in the combustion chamber, so head off and clean being the solution. I would do if hot first though with the throttle open
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 September 2014 - 04:55 PM
knackered oil rings.do a leak down test though, compression test doesn't really tell you anything.
Edited by ANON, 27 September 2014 - 04:56 PM.
#4 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 27 September 2014 - 05:03 PM
A compression test doesn't tell you anything? Yet you've determined that the oil rings are knackered, how have you managed that?
#5 Dusky
Dusky
  • 5,322 posts
Posted 27 September 2014 - 05:44 PM
Oil makes of a wet compression test = higher readings
#6 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 September 2014 - 05:48 PM
by knowing what i'm talking about ;-) dusky is cleva as well!!
#7 carbon
carbon
  • 2,590 posts
Posted 27 September 2014 - 07:13 PM
+1 for Rob Mac's suggestion.
If you have a significant build up of coke on the piston and cylinder head this will raise the compression. Fits with the sparking plug on number 4 cylinder being oily.
#8 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 September 2014 - 07:28 PM
isn't carbon build up generally caused by oil getting past the rings?
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 September 2014 - 08:12 PM
Yes or too rich mix
#10 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 28 September 2014 - 06:45 PM
OK time to own up to my ignorance. Can you describe a leak down test please?
#11 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 30 September 2014 - 06:21 PM
http://www.wcenginee...s/leakdown.html
#12 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 30 September 2014 - 08:17 PM
Thanks, looks and sounds beyond most of us without the special kit, though I'm wondering what you could do with a compressor and a flow gauge.
