Wiring A Heated Windscreen
6 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 September 2014 - 07:59 PM
I gave been putting this of for a couple weeks, but as the colder weather approaches it's time to get my ass in gear.
I think I know what I need to do (I have a wiring diagram).
I was thinking of using the same switch as for the existing rear screen. Can I do that?
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 September 2014 - 08:50 PM
If you run it through a relay yes, not directly though. The heated screens draw 17A per circuit (the circuits in single and twin circuit screens are the same oddly) and the rocker switches are rated at 16A. The rear screen is only 5A.
#3 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 28 September 2014 - 06:52 PM
The real question is do you always want them on together! In my experience you often want one and not the other. That's a lot of unnecessary current drain for the sake of a switch!
#4 cal844
cal844
  • 9,637 posts
  • Local Club: TFMOC
Posted 28 September 2014 - 09:17 PM
I agree, id be splicing the wiring on the input for thr rear, so the front is on a relay and seperate switch
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 28 September 2014 - 11:56 PM
I have a heated screen fitted to my mini and I ran it through a relay and I have had both front and rear screens on at the same time with no problems...and the front screen clears so quick within 5mins on winter morns........well worth the money.... :highfive:
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 October 2014 - 02:31 PM
Gonna wire this up this weekend.
I almost have my head around the wiring…..one further query where should i take the supply for the switch from (ignition controlled supply). or in other words the wire which runs to the switch and then pin 86 on the relay.
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 24 October 2014 - 02:43 PM
car is an spi
