Strange Knocking Noise From Behind Dash/bulkhead
Best Answer HarveyT , 02 October 2014 - 03:33 PM
take a look at the block to baulk head stabilizer bracket on baulk head I have repaired 6 of these over the last few years on members cars its quite common....
Had a look at my dads engine while he was out and the bolt holding the engine steady to the baulk head bracket was loose by about 3 quarters of a turn, and apparently now its stopped making the noise!
Thanks for the help everyone
Go to the full post
8 replies to this topic
#1 HarveyT
HarveyT
  • 127 posts
Posted 28 September 2014 - 08:06 PM
My dad's Rover Mini cooper 1275 (Right hand drive) has a strange knocking noise which we are really struggling to solve.
It sounds like it's coming from somewhere in the middle/right hand side of the car, from behind the dash, the bulkhead or the drivers footwell.
It only happens when you take your foot off or on the accelerator suddenly or when you brake.
We also can't replicate it when its parked by shaking anything.
The sound isn't worn engine steady bushes or mounts as they have all been done recently, and sounds like something knocking against the body or the dash, very similar to when you squeeze a plastic bottle and it pops back to shape.
Sorry if that description is a bit vague but we can't really pinpoint it to a certain location or think of what it could be!!
Any help would be much appreciated.
Many thanks,
Harvey.
#2 sledgehammer
sledgehammer
  • 3,098 posts
Posted 28 September 2014 - 08:16 PM
subframe lower rear mount ? - or cracking in that area
carb or exhaust hitting bulkhead / floor ?
you may not get the force to replicate the sound while driving
#3 HarveyT
HarveyT
  • 127 posts
Posted 28 September 2014 - 08:21 PM
We haven't had a look under the car yet for the subrame lower rear mounts but there is no cracking under the carpets.
As for not being able the force, we did think that but since we have changed the engine steady, the engine is solid! to the point where the car is rocking back and forth. The exhaust is fine as well.
#4 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 28 September 2014 - 08:28 PM
Could be a loose bolt somewhere which makes a noise under certain circumstances
#5 sledgehammer
sledgehammer
  • 3,098 posts
Posted 28 September 2014 - 08:40 PM
maybe leave it in low gear - hand brake off - ignition off - on flat ground
rock the car backwards & forwards while someone lies beside it - to isolate the noise
don't get run over - it's easy to do
#6 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 28 September 2014 - 08:57 PM
Yeah dont i know that!!
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 28 September 2014 - 11:59 PM
take a look at the block to baulk head stabilizer bracket on baulk head I have repaired 6 of these over the last few years on members cars its quite common.... :highfive:
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 29 September 2014 - 10:54 AM
you havent got anything hanging from your rear view mirror swinging about?
#9 HarveyT
HarveyT
  • 127 posts
Posted 02 October 2014 - 03:33 PM   Best Answer
