Mg Metro Lightened Flywheel?!?
Posted 29 September 2014 - 04:01 PM
Posted 29 September 2014 - 04:19 PM
Posted 29 September 2014 - 04:38 PM
Depends what you were ordering.... you can put a lightened flywheel on the engine, but needs to be the right one...
The whole clutch assembly consists of a spring, back plate, friction plate and flywheel... so if you're using a verto clutch system, you need a lightened flywheel for a verto clutch, if you're using a diaphragm clutch then you need a lightened flywheel for a diaphragm clutch. The two are totally different.
Posted 29 September 2014 - 09:53 PM
Edited by Jamesywick3, 29 September 2014 - 09:54 PM.
Posted 30 September 2014 - 12:55 PM
AC
