Stalling When Reversing
4 replies to this topic
#1 jt19
jt19
  • 745 posts
Posted 29 September 2014 - 06:43 PM
Hi
Every time I reverse the engine try to stall. Sometimes it does if I don't blip the throttle quick enough.
Just wondered what it could be?
Josh
#2 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 29 September 2014 - 06:49 PM
Could be wiring problems, as the engine will rock slightly the opposite way to normal, could be something like earth strap for example.
Could also try disconnecting the wire from the reverse light switch, underneath the gear stick, see if that solves it, as it may be shorting on something
#3 stevearch0
stevearch0
  • 310 posts
How's your engine mountings and steady bushes? Old nova I had, used to engage abit of choke on reversing, causing it to stall. Not sure if it could be the same for a mini....
#4 Richie83
Richie83
  • 1,495 posts
Posted 29 September 2014 - 07:04 PM
Had the same problem when driving forward because of worn steady bushes. Basically every time i moved the car the rocking engine pulled out a sensor. When stationary the sensor stayed in place, might be worth rocking the engine (if it rocks the steady bushes need replacing) and watch for anything coming loose or rubbing.
#5 jt19
jt19
  • 745 posts
Posted 30 September 2014 - 12:30 PM
Mounts are all new. Engine earth is good. Had it on the rolling road the other day and it didn't move much.
It has got a lumpy cam and a light flywheel though. Could it be that?
