Hi,
Do you need a speedo for an MoT?
Ta
Rod
Posted 29 September 2014 - 07:19 PM
Hi,
Ta
Rod
Posted 29 September 2014 - 07:24 PM
Posted 29 September 2014 - 07:34 PM
Posted 30 September 2014 - 02:37 AM
Posted 30 September 2014 - 07:22 AM
It needs to be there to record the mileage. Mechnical working condition is not checked.
Posted 30 September 2014 - 08:07 AM
Posted 30 September 2014 - 08:55 AM
Edited by Dan, 30 September 2014 - 08:56 AM.
Posted 30 September 2014 - 10:06 AM
Only going from what I was told by a tester when my mini (albeit years ago) failed due to a spotlight not working, maybe when he said matched pairs he was just meaning they should both work ? can't remember now. I did after all these years wonder how the 3 spotlight minis had MOTs !!!!! just shows you learn something each day !!
Posted 30 September 2014 - 03:42 PM
oh well - better fit it then :-(
I was hoping I could skip it for now.
As ever, ta very much folks,
Rod
Posted 30 September 2014 - 04:13 PM
As you will have to use the car on the road to get to MOT, wouldn't it be needed anyway?
Edited by gazza82, 30 September 2014 - 04:13 PM.
Posted 30 September 2014 - 07:08 PM
I was going to get the MoT done at the same time as the engine went in, then get it trailered back to my garage so I can do the full assembly of the interior. I am going to make my own dash with different gauges in so I was trying to avoid fitting the old 3 clock binnacle.
Rod
Posted 30 September 2014 - 08:47 PM
None of that is true.
Optional auxiliary headlamps (spot lamps) are never a reason for rejection whether working or not, only obligatory headlamps are tested. Incidentally spots are not required to be fitted in matched pairs under the lighting regs, they are required to be symmetrical. One lamp in the centre (per Italian Job replicas) is symmetrical. Fogs must be in pairs, spots/driving lamps/long range lamps etc. don't have to be.
Tis true, I am missing an optional auxiliary head/spot lamp, i.e. I only have one, the other is smashed and it wasn't an MOT fail.
I do have a speado tho..
