What does WaxStat refer to on a a SU HS4 carburetor?
Jack
Posted 30 September 2014 - 01:06 PM
Jack
Posted 30 September 2014 - 01:15 PM
At the very bottom of the carb is the jet assembly (the lowest point slighly above the bulkhead) - waxstat is the latter type and as the name suggests has a small "wax" (not sure whether it really is) element in it that adjusts jetting marginally in response to temperature - it's a fairly bulky assembly with debatable benefit....the early type is a fixed jet which is much slimmer in profile....
If you've a waxstat version and for whatever reason want to retro - convert it - its very very easy (for us in the UK!!!) remove the bottom cap - remove the waxstat element - replace with two one penny coins and reassemble - job done.....
the bottom of the carb there is a wax tremostat that self adjusts the mixture when hot.
more reading. http://www.theminifo...stat-hs4-carbs/
Posted 01 October 2014 - 12:24 PM
Thanks for the quick explanations.
Jack
