None of the panels have any damage to them unless stated. Most will probably have a few scratches from storage to the the e-coat but nothing major.
Collection is preferred but I will post the majority of items.
Located in Chaddesden, Derby.
Special thanks to Photobucket for not actually applying any of the image rotations or cropping I did!!
Genuine Panels:
Boxing plate for R/H inner A post £20
L/H A Panel £15
R/H A Panel £15
R/H floor (Front to Rear) with inner sill £55
Non-Genuine Panels:
Front panel £40
R/H A panel £8
L/H Inner sill repair £8
R/H Inner sill repair £8
L/H Check strap (A post stiffener) £8
R/H Check Strap (A post stiffener) £8
R/H Rear quarter £25 (Corner is slightly bent, see photo)
Scuttle Corner Repair LH £5
Scuttle Corner Repair RH £5
2 x L/H rear quarter repair panels £5 each
Sectioned Boot floor repair panel £10
Leftover from tubbed R/H wheel arch £5
Rear Valance with a bit of surface rust £8
Great condition roof with sunroof. Cut with about 6 inches or so of the pillars left attached. £30
Cross member bracket to bulkhead R/H was cut from a shell and I repaired the bottom section. £10
Rear quarter lower window panels cut from old shell. Need a bit of tidying up but £6 each or £10 for the pair.
Some panels I have listed aren't pictured and i've quite possibly not listed a panel that's photographed.
If you could PM me with any questions then that would be preferable.
Edited by leadly, 12 December 2014 - 11:10 PM.
