Hi I have bought a 1990 Mayfair 998cc to do up the car has been off the road for 8yrs. 1st time mini owner. I have cleaned out all varnish in carb and done engine oil flush as was rough idling. all though she starts without choke and fires straight away and sounds a lot quieter I was still lacking power so did a compression test and got zero reading on two cylinders and 120psi on other two. Valves seem free and no water in the oil when I did flush and no creaming under rocker cover. Ant suggestions will be helpful. Thanks
2 Cylinders No Compression
Posted 05 October 2014 - 04:25 PM
Posted 05 October 2014 - 04:45 PM
if the two that have zero compression are next to each other then I would suspect the head gasket
how are you valve clearances?
Posted 05 October 2014 - 05:37 PM
Cylinders 2-3 by any chance?
Minis don't tend to mix water and oil when the head gasket goes.
Oh, and welcome to TMF
Posted 05 October 2014 - 05:38 PM
Check:
Valve clearances, should be 0.012" cold.
Head gasket if the low cylinders are adjacent.
Vale sealing with valve seats.
If none of these identifies the problem come back on here for more help.
Posted 05 October 2014 - 06:13 PM
This was in my early daya when I had just started off with Minis. As I remember it all started with a heavy pinking sound with no over heating problems showing, but obviously it was to me unknowingly. It was only upon the gasket giving up and going through every thing after it all came to light
Posted 05 October 2014 - 07:05 PM
will check valve clearance tomorrow thanks..
Posted 05 October 2014 - 07:09 PM
No its 3-4 Cylinders and thanks
Posted 05 October 2014 - 07:11 PM
Check:
Thanks will check clearances tomorrow..
Posted 05 October 2014 - 10:33 PM
Edited by gazza82, 05 October 2014 - 10:34 PM.
Posted 06 October 2014 - 05:58 PM
Thanks for advice have checked the valve clearance and thats fine so think its take head off and investigate. Thanks will keep you updated
Posted 06 October 2014 - 06:03 PM
My money on head gasket blown on fire rings between cyls
how long was it run like this ?
they can burn / crack the block sometimes if run like this
Edited by sledgehammer, 06 October 2014 - 08:46 PM.
Posted 06 October 2014 - 06:54 PM
Almost certainly a blown head gasket. Don't run it until you have changed it.
Posted 06 October 2014 - 10:23 PM
Hi its been off road for 8yrs and bought it as a project to do up so will be stripping head off and getting it sorted thanks for advice will disconnect batt so nobody starts her up...
Posted 07 October 2014 - 01:56 AM
Good luck!
Hope you sort it
Edited by Ben_O, 07 October 2014 - 01:56 AM.
