Crank Damper Confusion
9 replies to this topic
#1 Craig89
Craig89
  • 600 posts
Posted 06 October 2014 - 10:19 AM
Hello all. I'm about ready to send my 1275 engine components off to be machined but the crank damper is giving me a head ache.
The one removed from the donor engine was in a pretty poor state (perished rubber etc) So I sourced a spare but its mass is notacibly larger, it's outside face is about 6mm deeper.
The one removed from the engine, part no. TAM2011, weighs 1.3kg
The other one, part number CAM4902, weighs 1.55kg.
If anybody can offer up some advice on the
subject I would much appreciate it.
Thanks, Craig
#2 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 06 October 2014 - 10:27 AM
Cant you just get the heavy one faced(lightened) to the right weight?
#3 Craig89
Craig89
  • 600 posts
Posted 06 October 2014 - 10:34 AM
I did think of that but I first wanted to make sure that the one that came off the engine is the correct one as it looks very similar to the one currently fitted to my 998.
I do also believe that they're weight effects there damping across the rev range?
#4 Craig89
Craig89
  • 600 posts
Posted 06 October 2014 - 06:59 PM
Bump
#5 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 06 October 2014 - 07:15 PM
Id imagine it would affect the damping
#6 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 06 October 2014 - 08:47 PM
AFAIK the smaller of the two were fitted to small bore engines (998 etc) and the larger dampers were fitted to 1275's
Edited by benjy_18, 06 October 2014 - 08:47 PM.
#7 Craig89
Craig89
  • 600 posts
Posted 07 October 2014 - 11:55 AM
That sounds logical. Can anyone confirm this?
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 October 2014 - 01:10 PM
Yes the heavier one was for the 1275 engine to combat a harmonic between around 5800-6200rpm, the 998 engine doesn't suffer from this though and used a lighter damper
#9 s3swiss
s3swiss
  • 26 posts
Posted 07 October 2014 - 04:07 PM
"a harmonic between around 5800-6200rpm" - yikes!
My ears are bleeding when my 998 get to those rpms - wouldn't be worried about a vibration - more the rods making a break for it!  :lol:
#10 Craig89
Craig89
  • 600 posts
Posted 07 October 2014 - 07:46 PM
Thats great thanks, puts my mind at rest now
