I am replacing my fuel regulator, and have a Sytec adjustable one up to 100psi. Am running retro fitted fuel injection system, using MPI tank. Before when I had the same unit, I ran the system like:
Fuel feed into T piece - one end to fuel regulator and one off to injectors
The bottom connector was the return
Fuel pressure guage on the other side of the regulator
Is this correct? Am not sure how the unit works, but I dont see what stops the fuel direct from tank going to the injectors from the pressure in the MPI tank pump via the T piece. It seemed to work before but maybe the MPI fuel tank pressure was enough to begin with and the fuel pressure regulator is not needed?
