I fitted two new front backplates to my 82 HLE and in very short order the brakes failed. They didn't fail as such, they just lost "pedal" until only the backs were working. I investigated and found the adjusters on the right hand side had backed off. They were actually loose in the backplate. The vendor, very quickly offered a replacement, but although slightly better, that too has lost it's adjustment.
This is a worry to me as my son is driving the car.
The left one seems ok, and the adjusters are noticeably tighter than the right.
So here are a few questions:
Has anyone else found this problem?
Are the replacements with the part number and RH and LH stamped (actually maybe etched) into them genuine parts? I noticed the old ones have lockheed also stamped in.
How available are good secondhand units, or are they all as bad as my old ones?
How difficult/expensive is it to switch over to disc brakies? I suppose good serviceable parts from a donor car would be the way to go.
I'm running 12" wheels, so probably standard parts would do for the conversion. I didn't want to convert, though as the car is almost stock.
Mart.
