Cylinder Head
Posted 11 October 2014 - 05:07 PM
Posted 11 October 2014 - 05:09 PM
Posted 11 October 2014 - 05:14 PM
Posted 11 October 2014 - 05:23 PM
Standard is about 1.24:1 I think.
Ultimately stage 2 is just a number.
I had a head ported and polished for my use (fast road).
It needs to be fit for purpose and matched to other components (cam, compression etc)
You may find you lose power with 1.5:1 rockers in certain area of the rev range and gain when flat out.
What are you using the car for?
Posted 11 October 2014 - 05:26 PM
Posted 11 October 2014 - 05:37 PM
If I was to change the rockers here's the ones if go for would I need anything ? I except for a new gasket
http://www.minisport...ockers-red.html
Posted 11 October 2014 - 05:41 PM
It's hard because you don't know what you've got.
The standard head is very poor on the A-series engine and porting work gives big improvements.
Calculating the compression ratio, and having it adjusted will help, then a fast road cam.
Something like this maybe?
Posted 11 October 2014 - 05:50 PM
Posted 11 October 2014 - 06:01 PM
Camshafts for the A-series are a relatively cheap way of releasing extra power, if you are confident you can take out the engine and fit it yourself. Otherwise it gets expensive paying a garage to do camshaft change.
Cam is swap usually done together with head improvements, and it helps to have these cam & head modifications well matched.
Posted 11 October 2014 - 06:10 PM
Posted 11 October 2014 - 06:25 PM
If you want other rockers : get 1.3 ratio for a road engine ;)
Posted 11 October 2014 - 06:31 PM
This is good advice.
You kind of need to know what you've got head wise though
Posted 11 October 2014 - 06:35 PM
Don't forget the exhaust boys, no point spending time on the cam and head without getting rid of all of the gases. Then of course there's the carb as well. That will need a reprofiled needle and a good setup on the rolling road to optimize everything.
