ive increased the studs on the rear to 80mm to compensate the width of my comp turbo rim, however im left with 3mm of stud length.
do you think ill be ok with this little thread or shall i order some 85's?
Posted 11 October 2014 - 06:57 PM
Posted 11 October 2014 - 07:04 PM
I would go longer to err on the side of safety.
so go for the 85's for the extra 5mm
Posted 11 October 2014 - 07:08 PM
What sort of seat do the wheels have - taper or cone? (it looks almost flat in that picture)
Depending on the depth of the nut, I would be looking at 90mm studs at least
Posted 11 October 2014 - 07:09 PM
flat mate, you thinking get them ground out a bit?
Posted 11 October 2014 - 07:13 PM
I don't know of a nut that has a flat seat without it being a sleeve type nut. It must be relying on the wheel being a good fit over the studs to make sure it's centred properly.
What does the nut look like?
Posted 11 October 2014 - 07:19 PM
the wheel sits snug in the studs, the nuts are just standard wheel nuts
Posted 11 October 2014 - 07:24 PM
Posted 11 October 2014 - 07:26 PM
This type?:
no sorry what i told ypu was a lie, i have these type - http://www.minispare...ure=350/CN5.jpg
Posted 11 October 2014 - 07:33 PM
Posted 11 October 2014 - 08:09 PM
No where near enough to be honest. Id go longer, and as above are the face of the alloy coutersunk to take the shape of you nuts or do the just sit flat against the alloy? Dont risk loosing a wheel at 80mph mate. Id say maybe 90mm too.
ill measure the excess form a std rim and match the diff, prob safest bet
Posted 11 October 2014 - 08:31 PM
Posted 11 October 2014 - 08:34 PM
That looks way too short to me. Depending on who you listen to, 6-9 full turns as a minimum seems the ball park.
Edited by megamini_jb, 11 October 2014 - 08:35 PM.
Posted 11 October 2014 - 08:55 PM
works for any car as far as I know. I understand it comes from 1-1.5 x diameter. I.e if the nut is an M10 it should have between 10 and 15mm of thread in it, ideally the 15mm. Have seen a few variances on the principle and it's obviously affected by pitch but as a rule of thumb it errs on the safe side if anything.Might be a daft question, but is that 6-9 fully turns just mini size, or any car?That looks way too short to me. Depending on who you listen to, 6-9 full turns as a minimum seems the ball park.
