Dash Clocks Wiring Confusion!
4 replies to this topic
#1 russyb94
russyb94
  • 73 posts
Posted 11 October 2014 - 10:05 PM
Hi guys!
i have the two clock dash in my mini, i have the big plug n speedo on but no power is going too the temp guage or fuel!
i have three spade connector wires loose but no terminals on the clocks for them!!!
Can anyone helo? there is a green/blue green/red and green/orange also the clocks have no illumination
984B3597-E9E7-43A8-9EA0-264FD4DF0B79_zps
B615CD8D-2E1D-475C-96CD-5ABE37EAB23F_zps
Edited by russyb94, 11 October 2014 - 10:06 PM.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 October 2014 - 11:05 PM
The wiring for all the clocks you have is in the multi plug. The extra cables you have are light green/orange which is power to a tacho, green and light green/brown which are for a flasher unit. The problem with the fuel and temperature gauges is likely to be the voltage regulator, which is inside the clock itself on that model. It's not a discreet component but is integrated into the clock. You will have to do a little testing with a meter to see if this is the issue. Lack of lighting isn't related though. Do the side and fail lights work?
#3 russyb94
russyb94
  • 73 posts
Posted 11 October 2014 - 11:11 PM
ahhhhh right so the flasher relay goes too the green/brown and then??  i apologise im not very confident with wiring lol
#4 russyb94
russyb94
  • 73 posts
Posted 11 October 2014 - 11:18 PM
unit sorry* dont suppose you know where the flasher relay connects do you mate?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 October 2014 - 06:15 AM
The plain dark green and the light green / brown are for the flasher unit.
