wonder if anyone can give some pointers ...
my engine is running lumpy at idle .. KC 266 CSI ignition ... the timing mark moves around the 10 mark using a strobe ... this has a new cam thinking the old one was worn out because it did it then ... so new cam new carbs new dizzy and still no real smooth idle ... tried different dizzys and still no joy .. cam is timed in at 106 spot on but still the mark moves around slightly around the timing mark when on the light .... any ideas ,...
could it be the coil
