Front Subframe
10 replies to this topic
#1 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 16 October 2014 - 03:05 PM
For sale is a single bolt, manual front subframe. It's for sale because I bought another one to get powder coated and then swapped them over. In perfect working order, no cracks or dents, just needs some cosmetic attention and it'll be perfect.
£30 collected from Hatfield. May be able to post but it wont be cheap.
2DD9B179-4ABB-4858-ADE3-FA333176C743_zps
9A47EF65-4494-4753-A27E-677A716C5337_zps
#2 bikenutmart
bikenutmart
  • 579 posts
Posted 16 October 2014 - 03:48 PM
HI, Would this fit my 1972 850 auto, Im going to manual g/box. Mart.
#3 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 16 October 2014 - 05:00 PM
I'm not 100% but I believe 1972 is a twin bolt per tower frame so it will not. If you have a look at the bulkhead on your car, if it has one hole in each corner and uses two large thick bolts it will fit. If there's three in each corner and it uses two thin ones then it wont.
#4 bikenutmart
bikenutmart
  • 579 posts
Posted 16 October 2014 - 08:46 PM
Havent got mini here at present, Can anyone help, re single or twin bolt? Mart.
#5 BUNYIP
BUNYIP
  • 67 posts
Posted 17 October 2014 - 03:42 PM
Mines a 1974 and a twin so a 72 will be a twin bolt rather than a single .think im right in saying you could convert it over but the single bolts are quite expensive plus there maybe rubber mounts that bolt underneath rather than direct thru the floor pan
#6 rolesyboy
rolesyboy
  • 34 posts
Posted 17 October 2014 - 07:27 PM
Subframe
#7 rolesyboy
rolesyboy
  • 34 posts
Posted 17 October 2014 - 07:29 PM
I have a four bolt subframe suitable for your needs. £35. Essex. Might be able to deliver if you want to meet in North East part if M25 (j28-j21)
Cheers. Mark
#8 Frecklez1990
Frecklez1990
  • 0 posts
Posted 01 November 2014 - 09:43 AM
Hi,
Is this still for sale?
And do you know if it would fit a 1994 Mini please?
Sophie
#9 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 01 November 2014 - 09:11 PM
It is and I believe it will. I think some later cars had the engine mounts a cm or two forward, but I'm not sure it makes much difference. I'm sure a quick bit of google research would confirm that
#10 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 10 November 2014 - 09:33 AM
Still for sale
#11 danm
danm
  • 502 posts
  • Local Club: Stringfellows
Posted 12 November 2014 - 03:35 PM
Tempting, I only want to use it to see if the spare aygo engine I have sits on it as per a possible experiment. Only in Hemel. Hmmmm decisions!
