Hi everyone I'm after some advice, so I'm rebuilding my rear subframe and have stumbled across a problem! I have the trailing arms in both sides however the brackets that sit at each end do not appear to line up! Initially i had negative camber brackets from minispares (pre formed so non adjustable) and because they didn't line up i assumed they were faulty and bent. I have just tried to fit standard brackets and these don't line up either! Are the thrust washers different? I have just gone through our spares and found straight and chamfered thrust washers? Would this cause a problem I will state all 4 that are fitted are currently chamfered! Could it be that the subframe or both trailing arms are bent at all??
Rear Trailing Arm Brackets
Pooley03
, Oct 19 2014 11:29 AM
4 replies to this topic
Posted 19 October 2014 - 11:29 AM
Posted 19 October 2014 - 11:43 AM
Posted 19 October 2014 - 11:45 AM
Thanks A cell, are any of them chamfered as it doesn't explain in the link
Posted 19 October 2014 - 02:50 PM
I think the inner one is thinner than the outer one. The outer one is the same as used on the front top arm. Can't remember about the chamfer.
Posted 19 October 2014 - 03:17 PM
Hi thanks for that info we put two non chamfered thrust washers on and its done the trick on one side now to do the other side! Appreciate your help and sending me the link as well!
