Rod Type Gear Change Issue
4 replies to this topic
#1 Jimbob98
Jimbob98
  • 71 posts
Posted 20 October 2014 - 08:46 PM
Hi, can somebody give me advice, I'm struggling to knock the roll pin out on the rod linkage.
Is it parallel because it seems it will only knock out one way due to the casing, or am I missing a trick
Cheers jim
#2 Tupers
Tupers
  • 4,173 posts
Posted 20 October 2014 - 08:47 PM
Put it into reverse and you should be able to knock it all the way through.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 October 2014 - 08:48 PM
Yes it's parallel, but if you use a punch that can slip inside the pin it will spread as you strike it and then won't move. Put the thing in reverse.
#4 Jimbob98
Jimbob98
  • 71 posts
Posted 20 October 2014 - 08:51 PM
Ahh, and by putting it in reverse il get the clearance I presume?
Many thanks for your replies, jim
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 20 October 2014 - 09:18 PM
Just gives easier access
