After searching here and reading a bunch of threads about rear drum removal I haven't been able to locate any info on the problem I'm facing. I have followed the steps outlined in the Haynes manual for drum removal (releasing the emergency brake, backing off the adjusters, etc.) and I've come to the point where I'm supposed to take the two retaining screws out of the drum and pull it off. However, there are no screws in the holes to release. Instead I have something with a flat surface with no slots for any type of screw driver where the screws should be. I can see that a PO has removed one screw but the remaining hole on the passenger side drum and both holes on the driver's said drum contain the flat surface retainers. They are flat and slick like the head of a nail.
Any idea what they are and how to remove them? In 30 years of working on all manner of cars I've never seen drum retainers like these.
Jack
