Which Crank Pulley
Posted 21 October 2014 - 05:44 PM
Posted 21 October 2014 - 05:46 PM
Posted 21 October 2014 - 05:48 PM
Posted 21 October 2014 - 06:49 PM
To make it short, the longer the stroke the lower in the engine revs the crankshaft tend to have a vibration.
On a 1275 is at around 6k rpm so a crank damper is added to lower these vibrations and make the engine last longer.
I dont think 998 A+ engines ever came out the factory with a damper fitted though.
Note: never swap dampers from an engine to another or you'll have to rebalance the whole rotating assembly (flywheel-clutch-crankshaft-damper)
Edited by jaydee, 21 October 2014 - 06:51 PM.
Posted 21 October 2014 - 07:59 PM
From memory its over 9000rpm when the 998 has issues with the harmonic.The larger damped pulley is a 1275 and the smaller if it uses one is smaller
Edited by KernowCooper, 21 October 2014 - 08:00 PM.
Posted 21 October 2014 - 08:09 PM
Posted 21 October 2014 - 08:10 PM
Posted 22 October 2014 - 06:45 AM
Bing (1)
