Coolant Leak
4 replies to this topic
#1 OllyGW
OllyGW
  • 51 posts
Posted 22 October 2014 - 03:55 AM
Bit of a novice but just got my mini back from the garage and was told there is a small coolant leak. Didn't say it was too bad.
Any suggestions as to where it might be? easy fix? basically want a little guidance to where it might be.
Thanks in advance :)
#2 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 22 October 2014 - 05:50 AM
How come they didnt tell you where it was leaking from?
Thats a bit lame as it could be comming from a variety of sources............
Can you post a pic once you hace spotted it?
#3 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,859 posts
  • Local Club: man Estate
Posted 22 October 2014 - 03:41 PM
That is vague!  Fill up the radiator then dry everything around your engine (airline and/or rags), run your engine and tell us what area it's leaking from.  Rad end, clutch end, high or low etc
#4 jaydee
jaydee
  • 8,565 posts
Posted 22 October 2014 - 07:25 PM
'Ok guy heres your car'
'Thank you heres your money'
'You also have a slow coolant leak'
'Ah..where does it leak from?'
'I dont know...find it and i'll fix it for you. See you!'
:bah:
#5 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 24 October 2014 - 11:48 PM
They should tell you where as the location will make a difference to the charge. Bypass hose v thermostat hose will be a different cost. I'm sure if you ask they will say where it is.
That aside If 'you' really can't spot the leak, check th fluid every day and see it is actually going down.
If it is then use some UV dye and a UV torch - £10 on ebay and you will easily find the leak without too much head scratching.
Charlie
