Toad Ai606
7 replies to this topic
#1 smudger50
smudger50
    Just On Tickover
  • 9 posts
Posted 23 October 2014 - 04:54 PM
Hi,
Firstly forgive me if this has been posted before.
I'm fitting a Toad Ai606 alarm & immobiliser into my 1988 mini at the weekend and wondered if anyone could advise which wiring circuits I should use to immobilise the car and if possible which colour wires am I looking for and where they are best located?
the car has no electric fuel pump.
I'm guessing the starter motor & possible y the coil.
The alarm has 2 circuits and the maximum load per circuit is 18amps.
If this is to sensitive to post publically then please private message me.
I have also attached the technical data sheet of the alarm.
Hope anybody can help.
Darren
#2 smudger50
smudger50
    Just On Tickover
  • 9 posts
Posted 26 October 2014 - 08:06 AM
Can Anybody offer any help & advice??
#3 RooBoonix
RooBoonix
  • 1,225 posts
Posted 26 October 2014 - 01:15 PM
Starter motor isn't a bad way of imobilising a car but a circuit which allows the car not to be bump started is good.
Remember that the quality and position of your immobiliser circuit joins is a key factor in the security of your car.
#4 smudger50
smudger50
    Just On Tickover
  • 9 posts
Posted 27 October 2014 - 07:40 AM
I've done the immobilisation on the starter but your right I do need to immobilise another circuit so it cant be bumped.
problem is which circuit as the mini are fairly basic with there options.
Alarm is all done apart from the 2nd immobiliser so any other advice or help would be appreciated.
#5 RooBoonix
RooBoonix
  • 1,225 posts
Posted 27 October 2014 - 08:18 AM
Well like you said they're fairly basic. It's your choice. Do what's best for your car, I have an spi injection model so I have more options with mine (and my alarm uses external relays so I can split the trigger wire to control as many circuits as I want) but do what you think is best for you
#6 smudger50
smudger50
    Just On Tickover
  • 9 posts
Posted 27 October 2014 - 11:33 AM
I will when I work out what other one to do.
what options are there apart form the starter which I've already done?
It needs to be wired in the car and the circuit needs to be no more than 18 amps
#7 RooBoonix
RooBoonix
  • 1,225 posts
Posted 27 October 2014 - 02:09 PM
Ignition is all I can think of to be honest but I'm not very familiar with the older models
#8 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 27 October 2014 - 09:27 PM
if you down load the whole booklet for the alarm it tells you what circuits you connect the immobiliser to from your alarm. It does need to immobilise the ignition system when you turn off your ignition to get its cat 1 status
