Converting Two To Three Dials
11 replies to this topic
#1 dave1010
dave1010
  • 114 posts
Posted 01 November 2014 - 02:50 PM
Hi all, my first post on here, so greetings.
I've recently bought a 94 1275 sprite and want to change the boring twin clock's to the triple and also fit a complete wooden dash, firstly is it easy to rewire including rev counter as guessing it's an electronic one, also can it be flush mounted onto the dash facia?
or would it be easier to hunt down three separate clocks?
Bit of a long one for my first post!
Edited by dave1010, 01 November 2014 - 03:20 PM.
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 01 November 2014 - 03:08 PM
It's an easy swap, the wires for the Rev counter are already there
#3 dave1010
dave1010
  • 114 posts
Posted 01 November 2014 - 03:18 PM
Coolio :)
#4 Ocado Man
Ocado Man
  • 186 posts
Posted 01 November 2014 - 03:59 PM
As Tamworthbay says 'easy'.
I bought from here - great service & rapid delivery - http://www.custom-consoles.co.uk/
or you could try - Fleabay
#5 dave1010
dave1010
  • 114 posts
Posted 01 November 2014 - 05:05 PM
Brilliant, look good, I have slate Alcantara to cover it and the door/rear panel's with.
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 01 November 2014 - 06:10 PM
The wires are there, 2 white/black, you need the rev counter which just clips on and a new facia which screws on :)
HTH
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 November 2014 - 06:46 AM
1 white/black and one light green/orange. If you choose to fix the rev counter pod by itself to your existing clocks you will ideally need the 3 clock version of the PCB to replace the 2 clock one, as making the lighting and warning lamps work without it is a pain and you would have to fabricate an earth for the tacho too if you didn't have it.
#8 Ocado Man
Ocado Man
  • 186 posts
Posted 02 November 2014 - 09:15 AM
Good old Fleabay - they've got everything.
http://www.ebay.co.u...=item20d3e4ba68
#9 dave1010
dave1010
  • 114 posts
Posted 02 November 2014 - 09:29 AM
Am going to fit the three clock version.
#10 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 02 November 2014 - 07:17 PM
Yes this is correct, i was checking my indicator relay on my 93 car( earth had worked loose!)
#11 dave1010
dave1010
  • 114 posts
Posted 02 November 2014 - 07:50 PM
i'm looking at a set of clocks, do I need the whole lot including the plastic surround even if I'm fitting a full length dash?
#12 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 02 November 2014 - 08:15 PM
No if you're fitting a full length dash, you just need the white plastic inner pod, which you'll usually then need to cut the down the indicator lamp tubes on, so that it fits flush to the back of your new dash. When you do the swap you can retain your original milometer reading, by removing the speedo instrument from inside the original 2 clock pod and swapping it over with the one in your new 3 clock pod
