How Loud Is Your Mini?
22 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 01 November 2014 - 04:37 PM
Curious to see how loud other's Mini's are. I've changed mine and would like to compare it to a stock 998.
Just a list of mods and a decibel reading if possible would be great!
#2 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 01 November 2014 - 04:53 PM
1000cc 1275 head, twin carbs , lcb manifold,  RC40 exhaust with only 1 silencer.
can't hear my self think :withstupid:
#3 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 01 November 2014 - 05:44 PM
A lot of it is down to the amount of sound insulation installed. That is none in my case so with a single box playmini exhaust its exceptionally noisy! I also suffer a nasty harmonic vibration of the exhaust at exactly 60mph...
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 01 November 2014 - 06:08 PM
With my 998(stripped out, no sound deadning) its loud, my 1275 has sound deadening behind the dash and carpets its alot quieter
Both cars are standard as far as i know, with stage one kit, full exhaust.
998 has a 2 inch full system with DTM back box
1275 has a
1.75 inch maniflow manifold
2.25 link pipe
3 inch piped back box
HTH
#5 Will16
Will16
  • 1,090 posts
Posted 01 November 2014 - 06:17 PM
Just went out and measured mine with an decibel meter app.
103dB at idle! I need to test it when it's going, much louder!
826912C5-175E-42F8-91A0-96344454C979_zps
#6 mab01uk
mab01uk
  • 12,538 posts
Posted 01 November 2014 - 06:37 PM
BL launched the 'Quiet Mini' in the Summer of 1980. It incorporated extensive sound-deadening in the floorpan, front bulkhead, dashboard, roof and boot, plus a new headlining material. The effect was to produce what could more accurately be called a 'quieter Mini'. Over the years it was slowly reduced under cost reductions and in the front floorpan area it seemed to promote rust by trapping the water leaks
Motor Magazine - July 5th 1980
#7 Dr s
Dr s
  • 428 posts
Posted 01 November 2014 - 06:45 PM
Mine runs a single box rc40, but you can't here that over the induction through the speedo aperture..
#8 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 01 November 2014 - 08:12 PM
Straight cut drop gears, blowing exhaust and just carpet = very loud
#9 Pauly
Pauly
  • 4,213 posts
Posted 02 November 2014 - 12:23 AM
Mine measured 117db in a sound off
#10 racingbob
racingbob
  • 3,061 posts
Posted 02 November 2014 - 10:25 AM
mines nice and quiet as far as the exhaust goes got a maniflow
BUT has a larger mid pipe and a 10" wide rear tail pipe
has a nice noise from the itg and substack tho
but has a nasty harmonic resinance at 3500 ( 60mph )
but goes as you rev more
#11 Dr s
Dr s
  • 428 posts
Posted 02 November 2014 - 11:21 AM
Did you mean 10 inch tail pipe? Photos please!
#12 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 02 November 2014 - 11:40 AM
I feel your pain on that one. Mine does exactly the same!
#13 racingbob
racingbob
  • 3,061 posts
Posted 02 November 2014 - 01:06 PM
is it like a drone that comes in then goes as you go thro it as go bit quicker
on mine its around 3300 to 3500
I don't know what to do to get rid of it
all I done is put plenty sound deadening and sound proofing to help
and it does help
#14 666junky
666junky
  • 1,225 posts
Posted 02 November 2014 - 03:44 PM
121 db with a 1330 engine straight through to a 2.5inch exit cherry bomb exhaust ;)
Edited by 666junky, 02 November 2014 - 05:37 PM.
#15 Cooperman
  • 23,326 posts
Posted 02 November 2014 - 03:52 PM
My rally car is 95 Db at 5000 rpm at 0.5 metres from the exhaust outlet and at 45 degrees to the centre-line of the car. Thus it meets MSA requirements for historic road rallying. That is with a Maniflow 'cherry-bomb' as the centre box and a reinforced RC40 rear box, all 1.75" diameter in order to achieve optimum power and torque from a 1310 cc engine
