Brake Pedal
mattyglover16
, Nov 02 2014 06:22 PM
4 replies to this topic
Posted 02 November 2014 - 06:22 PM
Hi is there anyway I can adjust the brake pedal on my 1994 rover Mini, as I would feel more comfortable with the pedal at a lower angle ? Cheers
Posted 02 November 2014 - 06:51 PM
You can bend the pedal a bit but it wont make much difference
Posted 02 November 2014 - 06:55 PM
You may also have issues with the pedal hitting the floor in an emergency stop situation, preventing full braking power being achieved. Unlikely to be an issue in a real world situation but something to consider
Posted 02 November 2014 - 07:18 PM
I cut mine 3/4 of the way through then welded it back up to suit. Easy job really apart from the clevis pin bit...
Posted 02 November 2014 - 07:54 PM
As you have a servo equipped car you can adjust the resting position with the nut at the servo clevis, but as said above ensure you do not limit the range of movement.
