What Battery Do I Need
11 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 02 November 2014 - 09:56 PM
As I says really got a 1380 running high cr , hi torque starter , 70 amp alternator just normal center speedo clocks and rev counter no radio etc or added extras
I've seen this spec battery in halfords I only really need it to get the car started and so it can be tuned up
#2 rally1380
rally1380
  • 1,893 posts
Posted 02 November 2014 - 10:30 PM
The big batteries people fit to minis are from a Pug 306 Diesel - think they are 075 batteries.  Biggest battery that will fit in the standard mini battery box.  I'm sure a google search would throw up something.  Last time I looked, Eurocarparts did a Bosch one with free postage.
#3 minilee94
minilee94
  • 3,523 posts
Posted 02 November 2014 - 10:40 PM
Hmm I don't really need the best off the best ATM just something better than a 2nd hand one lol that I have to jump start every time
The car is going away to bill Richards soon and if rather send it with a new battery
#4 minilee94
minilee94
  • 3,523 posts
I'm going to fit a proper gel battery on rear seat once mini is on the road
#5 Cooperman
  • 23,326 posts
Posted 02 November 2014 - 10:58 PM
For a high compression engine running a fairly high static ignition you need a high CCA figure. The best thing is to find a battery with a minimum of 500 CCA (that's Cold Cranking Amps). That is the most important figure.
#6 jaydee
jaydee
  • 8,565 posts
Posted 02 November 2014 - 11:15 PM
360 CCA is a bit on the low side, now dont know how high is your CR but i'd look at 440 CCA for a minimum. 500-560CCA will be best, these come in high amp size and since you have a 70 amp alternator shouldnt be a problem to charge such a battery.
Edited by jaydee, 02 November 2014 - 11:16 PM.
#7 samsfern
samsfern
  • 5,243 posts
Posted 02 November 2014 - 11:23 PM
I ran a 306 diesel battery in my mini, the compression ratio at the time was quite high, 12.5:1, turnt it over with no troubles.
Edited by samsfern, 02 November 2014 - 11:23 PM.
#8 minilee94
minilee94
  • 3,523 posts
Posted 02 November 2014 - 11:34 PM
Okay if it helps my starter is a 1.kw starter
#9 jt19
jt19
  • 745 posts
Posted 02 November 2014 - 11:37 PM
Bosch s5 075 or the varta equivalent. That's what I got on my 1380. I have 11.2:1 cr gas no trouble turning her.
#10 minilee94
minilee94
  • 3,523 posts
Posted 02 November 2014 - 11:45 PM
I just need the cheapest battery possible to fit ATM that why I though the halfords one
Standard 1.3 mini battery is about 330 cca that one is 360 I didnt think that would make a lot of difference my engine was a cooper running 10.5 from standard now is a 1380 running 11.1
#11 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 03 November 2014 - 08:57 AM
Halfords aint usually cheap....
075 from eurocarparts......from £39.99 http://www.eurocarpa...5-car-batteries
Lion Battery 075 3 Year Guarantee
Lion Performance batteries are able to withstand the pressures of day to day use, and are still excellent value for money. All Lion batteries carry a 3 year guarantee for peace of mind and are created to amtch original specifications.
  • Amp Hours (Ah): 60Ah
  • Cold Cracking Amp (CCA): 520CCA
  • Length: 247mm
  • Width: 175mm
  • Height: 175mm
#12 jt19
jt19
  • 745 posts
Posted 03 November 2014 - 10:31 AM
Look on ebay the vatara one is not too expensive. It's a good battery aswell. 5 year Warrenty.
