Edited by ADDvanced, 03 November 2014 - 10:43 PM.
Posted 03 November 2014 - 10:42 PM
Posted 04 November 2014 - 01:45 AM
Posted 04 November 2014 - 08:13 AM
Enjoy
Posted 05 November 2014 - 01:24 AM
I think your wings and side repeaters/lights are correct for a Canadian spec Mini, although if you where wanting to replace the wings you would need to replicate the holes for them in the new ones.
I reckon you will also be needing outer and inner sill repairs and possibly some floor pan repairs once you start to tackle the door step.
All being well I'll be in Canada myself by this time next year (I know you're in the States) I'll be bringing my cars with me so there will be 2 more Minis on the highways of North America by then!
Posted 05 November 2014 - 04:08 PM
Thanks guys! I'm going to be ordering fenders/wings without any reflectors or lights on the side, I don't feel this model is in anyway desirable or collectable despite it being kind of rare, so I'll be restoring it to more like a 1970 without them. The floor panel has been replaced already; the welds are ugly but it's solid.
My question was I tried changing the oil, but I have a canister style filter. What year did they start using spin on filters? Anyway, the center bolt rocketed out of the oil filter mounting plate due to spring pressure, and took 3 threads with it. Now it's stripped. I've ordered a spin on filter conversion kit, but there is a support in the grill area right in front of this thing, so I can't even get the old one off. Ideas?
Posted 08 November 2014 - 11:40 AM
What are you using to try and get the filter housing off with? It should be a relatively simple job to do, have you got any extension bars and universal joint for your socket set, so you can in behind the front panel support?
I think the filters changed from the cartridge to spin on filters in the early seventies.
As to your earlier question about the mirrors, yes they shoud in my opinion be mounted higher up on the flat part of the door skin.
Posted 09 November 2014 - 01:26 AM
I am using sockets and ratchets, mechanically taking it off the block isn't the problem. I've removed the two nuts holding it on. There is a vertical piece of sheet metal behind the grill directly in front of this area, so I'm not sure how the heck I am supposed to pull the oil filter housing off since it runs right into this metal bar that runs vertically behind the grill.
Posted 09 November 2014 - 09:02 AM
Can you not remove the mounting studs and slide it out?
Posted 23 February 2015 - 04:42 PM
Update: Wound up welding a nut onto the studs, then they came right out :)
Posted 23 February 2015 - 04:51 PM
Bit off topic but I like the black steels really suit the car !
Posted 24 February 2015 - 04:01 PM
Thanks! It came with hubcaps but they were too nerdy for me. Removed them the first night I had it.
