Diff Cover
7 replies to this topic
#1 psychobob
psychobob
  • 205 posts
Posted 03 November 2014 - 10:45 PM
Will a replacement refurbished diff cover need machining for a new pot joint? One of my pot joints has loads of play in it. Will a new diff cover sort out the play, or will it need a bush reaming? Never had to do a diff before, so a bit baffled.
#2 Cooperman
  • 23,326 posts
Posted 03 November 2014 - 11:09 PM
After fitting the new diff cover output shaft bush it needs to be machined to match the output shaft.
#3 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 04 November 2014 - 01:16 PM
or take the diff and a new pot joint, fix the bush and have it reamed so that the new pot joint fits properly. Then add the oil seal and mount the diff cover.
#4 psychobob
psychobob
  • 205 posts
Posted 04 November 2014 - 03:44 PM
is it likely to be just that bush that is causing all the play? it was leaking oil and I fitted a new oil seal but its only lasted a couple of months and its weeping again. can I swap it with the engine in situ too? will a normal engineering company be able to machine it, or is there anywhere anyone recommends? ideally in the north Manchester area?
#5 psychobob
psychobob
  • 205 posts
Posted 05 November 2014 - 11:19 AM
Anybody?
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 November 2014 - 12:26 PM
There's a subtle difference between reaming and machining.... Certainly don't hand ream a diff side cover..
For the bush to perform its correct job of supporting the output shaft and drive shaft coupling ( of whatever variety ) it must be machined perpendicular to the face of the diff side cover and centrally to the locating collar on that face, this can only be done effectively on a specifically designed faceplate on a lathe, or a mill at a push. A ream of the correct size can then be used to finish the bush or more often using a tool in the headstock of a lathe.
Failure to do this will mean premature wear and failure, and back to square one...
The alternative is a good used 2nd hand one...
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 05 November 2014 - 12:56 PM
I keep a small stock of rebuilt side plates with new bushes. £25 inc postage to uk. I will need your old one in exchange. I have a suitable lathe mounted tool as described by Guessworks for doing just this job.
AC
#8 psychobob
psychobob
  • 205 posts
Posted 05 November 2014 - 02:39 PM
I've actually just ordered one from ebay, that I'm assured is in good order, so fingers crossed.
