Hi Folks,
Looking for some opinions. Have a '92 SPi cooper. Car is running fine, I suspect a little lean possibly,
but not entirely sure about that. Idles sweet and everything too. I've noticed however that on occasion,
if the car is idling and I give it a sharp blip on the throttle, it can backfire in the inlet. Doesnt
happen every time, and no such issues when driving. It does need to be a sharp blip to cause it.
I've still to service the dizzy cap and rotor arm and leads, although I have renewed the plugs and
also it has a recently cleaned and oiled K&N filter element in the standard air box. Vac pipes seem
to be in good condition too.
I have a theory that it could be due to the fact this car uses the throttle switch system. I had to replace
the throttle switch when I bought it, as it was seized shut, so it is a brand new switch which I have tested
and it is fine,however I wonder if maybe there is a response time associated with the ECU detecting that
the switch has opened. I know that if you rev the car with the switch shorted (as was the case when I viewed
the car) it will backfire.
I will check the throttle pot etc and inspect the condition of the dizzy cap and rotor arm but just wanted
to see if anyone else has encountered this and resolved it?
There is a similar thread on here, but it didn't really provide much insight in my case.
Thanks!
