Gaz Shocker Settings
7 replies to this topic
#1 fixitphil
fixitphil
  • 20 posts
Posted 07 November 2014 - 08:20 AM
hi can anyone with gaz shockers tell me what there settings are for the road please, iv just put a set on ,the resistance is more than my standard shocks even on say three clicks from soft ,they are twenty clicks alltogether cheers phil
#2 racingbob
racingbob
  • 3,061 posts
Posted 07 November 2014 - 08:52 AM
you may find it varies from person to person
all I done with my spax I set on say 3 on front and built up
each test drive until felt happy with front not dipping to much
but not to hard
I ended up on number 7,  2 years later its now 9
the back wont be nowhere as hard probably half the front
#3 fixitphil
fixitphil
  • 20 posts
Posted 07 November 2014 - 06:12 PM
ok cheers il do that , when it stops raining il take it over the local speed humps where it used to rub.
#4 kezzkitkat
kezzkitkat
  • 714 posts
Posted 07 November 2014 - 06:18 PM
I had mine on 12 but im a little brat so drive like a nutter
Then moved onto coilovers
#5 Carvell
Carvell
  • 316 posts
Posted 07 November 2014 - 07:30 PM
I was told by a suspension guy the back should always be stiffer by at least four clicks. Something about when cornering it's actually the pressure on the rear outside wheel that's important.
#6 racingbob
racingbob
  • 3,061 posts
Posted 07 November 2014 - 08:48 PM
my race mini was 9 front and 4 back using spax on 12 or 16 clicks maximum cant remember now
in 1998 and won the championship on this set up and drove realy well
it was a historic mini
#7 fixitphil
fixitphil
  • 20 posts
Posted 07 November 2014 - 10:16 PM
why does standard shockers have the same resistance on the front and rear shockers, also say you get 25% uprated they are the same. but we set these up harder on the front .
#8 racingbob
racingbob
  • 3,061 posts
Posted 08 November 2014 - 12:06 PM
let me know how you get on
just try what I said its the only way realy
by putting mine up 2 or down 2 I notice the difference
not as good or to hard
problem is its a road car and your trying to get top handling
with some comfort
