Ouch!
8 replies to this topic
#1 998ccMike
998ccMike
  • 71 posts
  • Local Club: Bristol Mini Drifters
Posted 07 November 2014 - 10:16 AM
First casualty of the bad winter weather,, caught a post as I was driving down a dark country road.Now looking to get this sorted, Not the start to winter I was hoping for tho.
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 07 November 2014 - 10:30 AM
you might be lucky and be able to knock that out from behind. Personally I would consult a "smart repairer", they're trained in paintless dent removal so they might be able to get that looking straight without removing the paint and needing a respray.
#3 Grimshaw17
Grimshaw17
  • 221 posts
Posted 07 November 2014 - 11:01 AM
As said above, I definitely think you could get that pulled out by a specialist
#4 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 07 November 2014 - 12:11 PM
might just be a photo angle but the wheel looks a little out of sink ???
#5 998ccMike
998ccMike
  • 71 posts
Posted 07 November 2014 - 12:25 PM
The tyre is currently flat, and the plastic wheel arch has been smashed, so I think it just looks a bit odd, I did notice the window has been forced out under the impact and will not close now,along with the panel gap where thee door meets the quarter panel.
#6 deanymini
deanymini
  • 771 posts
Posted 08 November 2014 - 08:20 AM
Is the tyre flat because of the impact?
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 November 2014 - 08:31 AM
That is too crumpled for a smart repair plus the window sill is damaged too.
That will need more attention i'm afraid.
Ben
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 08 November 2014 - 09:42 AM
I agree with Ben, you might make it look a bit better by trying to knock it out but you'd never get it perfect.
The bottom of the window should pull down when you push the dent out though.
#9 Covert
Covert
  • 526 posts
Posted 08 November 2014 - 09:43 AM
I would be checking that rear wheel too, the tyre might be flat and the wheel arch missing , but the wheel looks too far forward in the wheel arch....
