Inertia Starter Spring Source
7 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 07 November 2014 - 09:23 PM
I inadvertently discarded the lightweight coil spring for my inertia starter pinion drive.  Can someone suggest a source for  same?
Thx.
Attached File  DSCN6080.JPG   61.17K   11 downloads
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 07 November 2014 - 09:41 PM
Check eBay item:  261629842013
The listing says "3 watching".  Are you one of them?
EDIT:  Also see eBay item 350723792365
Edited by dklawson, 07 November 2014 - 09:43 PM.
#3 newenglandmini
newenglandmini
  • 646 posts
Posted 07 November 2014 - 09:50 PM
Doug, thanks for the fast reply.  No I wasn't, but you've solved my problem!
#4 newenglandmini
newenglandmini
  • 646 posts
Posted 12 November 2014 - 10:52 PM
I received the spring I thought I was missing and attempted to assemble the starter.  In doing so I noted that what appears to be the same square-sectioned spring inside the pinion assembly.  Is the spring inside the pinion assembly the one shown in the drawing above, and did I not lose the spring?  Are both light coil springs required for assembly?
Attached File  DSCN6081.JPG   54.25K   1 downloads
Attached File  DSCN6084.JPG   46.88K   2 downloads
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 November 2014 - 03:39 AM
Good question.  I simply don't remember and cannot answer your question.
Without a spare starter to disassemble all I can suggest is to review exploded diagrams such as the one shown in the link below.
http://www.collectio...98&subject=7839
Edited by dklawson, 13 November 2014 - 03:46 AM.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 13 November 2014 - 11:39 AM
Only one light spring is required. It is located inside the pinion assembly and cannot be removed without pinion dissasembly.
AC
#7 newenglandmini
newenglandmini
  • 646 posts
Posted 13 November 2014 - 12:49 PM
Thank you AC.
Doug, the drawing you provided appears to be of a different starter.  I don't recall seeing a tapered spring, and items I, J and G don't match any parts from my starter.
I'm going to reassemble as per AC's instruction, and I'll not install the NOS spring I purchased.
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 November 2014 - 03:54 PM
Fair enough.  I haven't worked on a Bendix unit in several years so my memory of its internal bits is vague at best.  Trust AC and his advice.
