Stubborn Wheel Nut Cover
9 replies to this topic
#1 998ccMike
998ccMike
  • 71 posts
  • Local Club: Bristol Mini Drifters
Posted 08 November 2014 - 11:51 AM
Sounds daft, but I have a stubborn wheel stud cover that will not come of......it should be a two second job to remove these prior to undoing the wheel stud, but not the case I have tried small pri bars and pliers and bare hands with no luck.....any body had this issue before? and any ideas?
http://www.minisport...ini-wheels.html
Edited by 998ccMike, 08 November 2014 - 12:01 PM.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 08 November 2014 - 12:01 PM
Wheel stud cover? got a picture of it?
#3 998ccMike
998ccMike
  • 71 posts
Posted 08 November 2014 - 12:03 PM
Hi just found the offending part on Minisport, Its the cover for the wheel nut
wheel nut cover - http://www.minisport...ini-wheels.html
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 November 2014 - 12:06 PM
Thread title edited to say "nut cover" instead of "stud cover".
#5 alex-95
alex-95
  • 6,042 posts
Posted 08 November 2014 - 12:17 PM
They don't need to be taken off.
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 08 November 2014 - 12:25 PM
Only thing is if you don't take the covers off the nuts then they get marked/damaged by the spanner. So OP needs to take them off to avoid this damage I assume. Also as he says normally pull off easily with hand.
OP try plus gas and a little patience, then try again.
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 08 November 2014 - 12:46 PM
Try using a 6 sided 11/16" socket and the cover dose not have to come off or get damaged .
The covers do look like they come off but they don't its how there are made for the late type coopers.
summit like this http://www.ebay.co.u...=item43c5be5cc3
Do not use the metric equivalent as you will damage the cover.
Edited by ukcooper, 08 November 2014 - 12:51 PM.
#8 998ccMike
998ccMike
  • 71 posts
Posted 08 November 2014 - 01:06 PM
Hi thanks for the advice, I'm currently giving them a little soak with some penetrating fluid to see if it loosens them, I did attempt to undo the nuts with thee covers in situ but the covers make the nut just a little larger than a 17mm dia, first time ever I have had this issue.
#9 998ccMike
998ccMike
  • 71 posts
Posted 08 November 2014 - 03:06 PM
All sorted now, many thanks tho for advice and help.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 November 2014 - 07:18 PM
No, the covers make the nuts 11/16". They aren't covers, they are part of the nut and should not be removed. With the chrome cap off the nuts are no particular size. Once they have been removed the nuts invariably corrode underneath and then the chrome cap expands and deforms. Then you have to hammer a socket on them to turn them.
