Timing Plate Bolts
4 replies to this topic
#1 MiniHead95
MiniHead95
  • 168 posts
Posted 08 November 2014 - 01:57 PM
hello,
I am in need of brand new Timing chain plate bolts, I already have bolts for the timing cover, just not the plate, was wondering if anyone knew where I can get some :) cheers for any answers (pic illistrating below)
#2 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 08 November 2014 - 02:01 PM
http://www.minispare...ber.aspx?1~2~15
Hope this helps
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 08 November 2014 - 04:58 PM
well you need 3 for the cam shaft retainer, 3 large bolts for block, 2 very short for bottom of cover as not to dig into G/box......and what sort of timing chain are you fitting if std then your ok but if a duplex set up then you will need to countersink holes at back of small pulley....
#4 MiniHead95
MiniHead95
  • 168 posts
Posted 08 November 2014 - 06:25 PM
Will be a duplex
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 08 November 2014 - 11:26 PM
then you will have to remove the 2 hex bolts behind small gear and then countersink the holes and fit counter sunk set screws......
http://www.minispare...px|Back to shop
