There are two things to balance
Idle
load
You set the balance with a flow meter at around 1k idle (its a lumpy camshaft you have)
The balance under load is determined by piston rise-fall time, springs, dampers and yes, dashpot oil
Bear in mind that switching to standard airbox will affect mixture to the point you'll need another pair of needles different to those you use with cones and stacks
Yeah ![]()
But ( when looking to keith calver's tests) the standard airbox with K&N inlay filters etc should flow similar/even a bit better, so the fuelling won't be as drastic 'out' as it is now ![]()
I picked M needles initially, because I'm running a cooper setup ( or similar) only the cam is a bit wilder than the standard cooper cam it seems ![]()
