Interior Light - Replacing With Led
14 replies to this topic
#1 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 12 November 2014 - 06:31 PM
Hi all,
I searched but wasnt able to find a definitive up to date answer on this so...
I would like to replace the interior light on my 1993 Open Classic with something a bit brighter.
Is there a led bulb or led unit that is a straight swap? Would appreciate if someone could point me in the right direction.
Thank you,
James
#2 robminibcy
robminibcy
  • 1,516 posts
Posted 12 November 2014 - 06:36 PM
Yes straight swap, I think they use a festoon bulb. Can get them from ebay cheaply. Only thing to bear in mind I leds only work one way round so if you fit it and it doesn't work just turn the bulb roun.
#3 b_sdaddy
b_sdaddy
  • 643 posts
Posted 12 November 2014 - 06:39 PM
Yes. Original 5w 12v festoon bulb can be replaced directly with LED - just search for LED 12v interior festoon..
#4 b_sdaddy
b_sdaddy
  • 643 posts
Posted 12 November 2014 - 06:40 PM
ooops, sorry - sent at the same time as rob.
#5 1984mini25
1984mini25
  • 8,787 posts
Posted 12 November 2014 - 06:41 PM
Edited by 1984mini25, 13 November 2014 - 12:58 PM.
#6 robminibcy
robminibcy
  • 1,516 posts
Posted 12 November 2014 - 06:42 PM
http://m.ebay.co.uk/...4451?nav=SEARCH
Something like this would be ideal.
#7 mr3speed
mr3speed
  • 408 posts
Posted 12 November 2014 - 06:45 PM
Old hat. COB is alot brighter
http://www.ebay.co.u...=item4d1e9a806b
#8 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 12 November 2014 - 06:47 PM
I have one of these fitted , loads bettter
#9 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 12 November 2014 - 07:41 PM
Excellent, thank you very much everyone.
#10 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 14 November 2014 - 02:54 PM
I had a look at my interior light today and took the photo below. It doesn't look like the bulbs you guys have kindly have recommended would work with this type.
Any ideas from anyone? Looking for the 'quick win' if there is one!
[attachment=166683:interior light.jpg
Thanks.
James
#11 1984mini25
1984mini25
  • 8,787 posts
Posted 14 November 2014 - 03:13 PM
Like I said before, then later deleted as I was pretty much ignored. An led bulb isn't a direct replacement for the later interior light. The bulb only fits one way and as standard the interior light is wired to have two earth and one live. You can however fit one (I just have in my 25 project thread page 11) you just need to do a simple bit of rewiring and solder and extra wire to the end of the led bulb itself.
#12 mr3speed
mr3speed
  • 408 posts
Posted 14 November 2014 - 05:53 PM
Id change that lamp for a Cree or COB panel lamp
Something like this. COB is silly bright
http://pages.ebay.co...id=331378583181
#13 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 14 November 2014 - 06:42 PM
Well thank you for replying again. Will take a look at your project page.
Thank you.
#14 Richie83
Richie83
  • 1,495 posts
Posted 14 November 2014 - 06:45 PM
is this a direct replacement?
#15 mr3speed
mr3speed
  • 408 posts
Posted 17 November 2014 - 07:23 PM
If your lamp base looks like one of the adaptors then yes. You cant go far wrong, to be honest buy any 12v COB panel with a diamention to fit inside the housing and use two crimp connectors to hook it up. Job done.
