Recommend A Distributor
13 replies to this topic
#1 Coxie
Coxie
  • 461 posts
Posted 12 November 2014 - 08:03 PM
So, the distibuter in my 1275 has an oil leak through the shaft. Thought I had cured the problem but it still leaks.
The engine is an a+ 1275 with ultralite flywheel hif6 carb but camshaft unknown.
Distributer is 41768 A 45D4 no vacuum with luminition fitted.
I've had a rough quote to rebuild this distributer but at £180 plus vat it seems pointless
Could anyone recomend me a distributer for my engine as I'm looking at loads and there is a huge diference in price range and to be honest I'm pretty clueless in this department.
Edited by Coxie, 12 November 2014 - 08:04 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 November 2014 - 08:18 PM
Cam and head and compression would info would help but is its unknown, what does it go like and any idea of the power its producing? if its used on the road a Vacuum Advance who help with torque on a light throttle and mpg, and is a must really
Edited by KernowCooper, 12 November 2014 - 08:21 PM.
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 12 November 2014 - 08:36 PM
I have used the accuspark ones and they work well, not sure what range of advance curves they have though. Might be worth a call.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 12 November 2014 - 08:59 PM
a 123 dizzy will have 16 programed curves in you just need to know if its for an A-series or an A+ with or without vac advance
#5 Coxie
Coxie
  • 461 posts
Posted 12 November 2014 - 09:13 PM
It is a bit of a pig with the engine being such and unknown.
It came out if a mk2 rally car and I had the full intention of sending it off for a rebuild when I got it but when we took the head off it still had honing marks in the bores and a mechanic and a local engine builder were pretty sure it hadn't long been rebuilt.
It runs lovely and sounds a little but not to cammy on tickover but that could be the ultralight flywheel maybe.
The history file that came with the car the engine came out of did state it was a longman unit but just because there is a plate on the rocker doesn't mean it's the real deal.
Edited by Coxie, 12 November 2014 - 09:14 PM.
#6 Coxie
Coxie
  • 461 posts
Posted 12 November 2014 - 09:16 PM
That would be ideal but £300 odd notes might hurt a bit.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 November 2014 - 09:28 PM
Try a Aldon Yellow with vacuum advance
#8 Coxie
Coxie
  • 461 posts
Posted 12 November 2014 - 09:32 PM
That's what I had on a previous car and never had any troubles with it.
A bit more in my price range too.
So would that do away with the luminition gear that I have in the car at the moment.?
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 November 2014 - 10:00 PM
If your luminition fits the Aldon Base Plate use it.
#10 Coxie
Coxie
  • 461 posts
Posted 12 November 2014 - 10:11 PM
Thanks for the help bud.
#11 Spider
  • 15,684 posts
Posted 13 November 2014 - 12:52 AM
For the money, I'd buy one of those Lucas copies that are so cheep (but have curves all over the shop :whistling: ), lock out the centrifigal advance, and fit up an Acuspark Stelth black box, then you can optimise your curve and if you change your engine spec down the track, you can easily change the curve again to suit. For a road car that has an SU Carb, I would recommend one with a vac advance.
#12 Coxie
Coxie
  • 461 posts
Posted 13 November 2014 - 06:57 AM
Found this last night lucas 41768 59d4 new unused. £39 asking price.
Looking online it says for 1275 gt 1973 onwards.
Worth it?
If it gets me going I can alway upgrade to the aldon at a later date when funds allow.
Edited by Coxie, 13 November 2014 - 07:02 AM.
#13 Craig89
Craig89
  • 600 posts
Posted 13 November 2014 - 03:09 PM
That may not be suited to an a+ engine given its for a 1973 onwards
#14 Coxie
Coxie
  • 461 posts
Posted 13 November 2014 - 03:15 PM
Ahh that was me being an idiot. Was meant to say 1978 onwards
