1992 Rebuild - Trashy To Classy
52 replies to this topic
#31 rob mini
rob mini
  • 1,420 posts
Posted 28 June 2015 - 03:52 PM
So after a lot of electrical gremlins and faulty components the wiring is complete and ready to go. Time to start on the interior build which has kind of centred around the fibreglass dash that came with the car. I decided to use some of the same material as the textured headlining from optimise automotive to cover it. Im really pleased with the results so far!
Edited by rob mini, 28 June 2015 - 03:53 PM.
#32 rob mini
rob mini
  • 1,420 posts
Posted 05 July 2015 - 08:52 AM
Suspension and brakes finished! I noticed that although the ride height is balanced, the front right hilo is adjusted a lot shorter than the rest. Anyone got any ideas what could cause that?
#33 rob mini
rob mini
  • 1,420 posts
Posted 19 July 2015 - 09:20 PM
After getting it back up and running I tried to tune it a little and I found the mixture screw well and truly siezed. After hours trying to sort it and cracking the original carb body trying to free it off a replacement was sourced. Now running much better after a rebuild!
Some progress now made on the interior
Dash board trimmed and test fitted, just need to get the centre console done to match
Carpet down and drives seat mounts sorted, starting to look like a real car again!
#34 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 20 July 2015 - 06:26 AM
I do like the red carpeting.
#35 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 July 2015 - 08:03 AM
Really nice work on the dashboard and carpets, looks great :)
#36 rob mini
rob mini
  • 1,420 posts
Posted 20 July 2015 - 07:00 PM
Thanks for the comments, all coming together finally and will hopefully get it booked in for mot soon!
#37 rob mini
rob mini
  • 1,420 posts
Posted 21 July 2015 - 08:20 PM
Dash board and centre console finished and wired. Very pleased!
#38 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 21 July 2015 - 09:02 PM
Looks great, but how do you access the heater controls?
#39 rob mini
rob mini
  • 1,420 posts
Posted 21 July 2015 - 10:00 PM
The fan control is now on the dash switches and i have locked the heater to windscreen heating as i only plan to use the car in summer. The heater valve and choke are both on brackets underneath the dash to keep things tidy
#40 Minidarren83
Minidarren83
  • 1,207 posts
Posted 23 July 2015 - 09:17 AM
Hi mate did you use stretch stuff for the dash I have the same one and want to cover it
#41 rob mini
rob mini
  • 1,420 posts
Posted 23 July 2015 - 12:24 PM
It's material from optimise automotive, they sent some leftover from the headlining and it seemed perfect for the job. I'd recommend having a chat with them
#42 GraemeC
GraemeC
  • 7,467 posts
Posted 24 July 2015 - 07:44 AM
Ride height - getting the ride height looking correct is only half the battle, ideally it would be corner weighted.
The rear offside corner is heavier due to the fuel tank (especially when full) so that corner wants to sit down further and hence lift the front nearside.  Natural thing to do is adjust the front nearside hi-lo to bring it back down, whereas with corner weighting you'd probably lift the rear offside.
In a road car, setting it on looks is usually enough - the length of the hi-lo doesn't really impact the handling per se.  If it was a race car, you corner weight it and ensure the balance was spot on.
#43 rob mini
rob mini
  • 1,420 posts
Posted 04 August 2015 - 09:07 PM
Just want to say a huge thank you to Will16. I managed to some how lose my bonnet pin spring and he sent me one refusing to take any money for it. Really helped me out I now have a bonnet that opens and closes correctly on its cable.
I understand what you are saying about corner weighting, I had my grass track car done a few years ago and it really helped it get off the line. If I find I start tracking this I'll probably have it done.
I'll get some more pictures up soon, it's getting close to being ready for MOT, really looking forward to driving it!
#44 rob mini
rob mini
  • 1,420 posts
Posted 05 August 2015 - 09:42 PM
A few snaps almost ready for MOT. Just need to get a new exhaust system sorted as I really don't like the dtm. What do people recommend, maniflow or rc40?
#45 Cambelt
Cambelt
  • 158 posts
Posted 02 September 2015 - 12:51 PM
I've got a maniflow on mine gives a nice note and with 1.75 exit it doesn't get to the point where you can't hear the radio or people talking in the car.
Great work you've done there she's a beauty
