U-Pol Seam Sealer Under Por-15
5 replies to this topic
#1 MiniMoe2008
MiniMoe2008
  • 166 posts
  • Local Club: None Around Here
Posted 13 November 2014 - 08:18 PM
Trying to figure out if it would be best to POR-15 my underside first, then apply seam sealer followed by POR-15 Chassis Top Coat. Any suggestions?
#2 KaneH
KaneH
  • 73 posts
Posted 14 November 2014 - 07:57 AM
Best thing to do is prime, seam seal and then top coat.
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 14 November 2014 - 08:39 AM
Im for either way. If brush painting the underside for example, i try to get some paint to "run" into the gaps/seams/joins. I then seam seal over the top. You could seam seal then paint over, but what happens if the seam sealer comes out?
#4 MiniMoe2008
MiniMoe2008
  • 166 posts
Posted 14 November 2014 - 08:18 PM
Thanks for the suggestions. I'm think por15 coat first them seam sealer and then top coat. and yes I'll be brushing it on. Thanks!
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 14 November 2014 - 08:22 PM
You need to check to make sure the seam sealer does not react with the POR15. I normally use a Zinc rich primer forced into the joint then seam seal followed by stonechip then prime and paint.
#6 MiniMoe2008
MiniMoe2008
  • 166 posts
Posted 15 November 2014 - 06:42 PM
I've e-mailed them. Thanks
