hi all here is my new project i got this 2 weeks ago and as it sits is still as it is.
i was given a rear end to rebuild this out of but the only usable panel is the rear seat back so this will be getting used.
this is the seat panel i intend on using so got about sorting it
you may have noticed the two hole that are holding it should not be there this is were it had rusted through were they are welded to the waste rails from factory
then had to rub back all the places were its going to be welded and covered in weld through primer for some added protection.
Edited by MINIMADrt, 03 April 2015 - 09:32 PM.
