Mini Rollover Jig
8 replies to this topic
#1 minimadhenry
minimadhenry
  • 51 posts
Posted 14 November 2014 - 10:57 PM
hi I am building rollover jigs which will fit on all minis with or without frontend on please wiat for some pics need to down load some i can arrange for these to be delivered on a pallet or collection in person the cost of the jig is £175 please ring me on 01366387265 evenings  cheers henry
Edited by minimadhenry, 14 November 2014 - 11:09 PM.
#2 kezzkitkat
kezzkitkat
  • 714 posts
Posted 15 November 2014 - 05:13 PM
Is the jig a pole or subframe/shock mounted ?
#3 minimadhenry
minimadhenry
  • 51 posts
Posted 15 November 2014 - 05:30 PM
it is subframe shock  mounted please take a look i have them on ebay
http://www.ebay.co.u...984.m1555.l2649
Edited by minimadhenry, 15 November 2014 - 05:33 PM.
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 November 2014 - 09:28 PM
Are the pictures on the eBay advert of the finished product?
I keep looking into Jigs for mine but think i would be better off with a pole type one as the design you are using restrict access so much meaning you wouldn't have good access to key rot areas such as floors, toe board, bulkhead and i would be worried about the shell twisting if i cut parts out while it was on the jig.
When you say you have used this design, did you have any problems with access or twisting when cutting out panels?
I would be happier if the welding was a bit beefier on the joins too.
Ben
#5 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 15 November 2014 - 09:54 PM
won't work on a clubman.
#6 minimadhenry
minimadhenry
  • 51 posts
Posted 15 November 2014 - 11:13 PM
Ben
as you can see in the pictures you have very good acess to floor, toe boards the welds on the joints are fine a shell can twist with a pole at least with my design you do not have a pole inside the car and no need to cut a hole in rear bulkhead
#7 minimadhenry
minimadhenry
  • 51 posts
Posted 15 November 2014 - 11:16 PM
I can make an adaptor up to fit a club man front
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 November 2014 - 11:29 PM
Ben
Thanks for the reply.
i think ill have a go at making one though. £175 is a bit too expensive for me
#9 CambridgeLee
CambridgeLee
  • 24 posts
  • Local Club: Cambridge?
Posted 29 November 2014 - 06:53 PM
I have one of these and can vouch that they are well made and do the job nicely.
