Battery Issues
Best Answer Craig89 , 16 November 2014 - 02:08 PM
Whatever gives the best connection over the battery terminal, the best solution would be a bush with a slot cut out of it so that it tightened onto the terminal as you tighten the clamp around the bush if you see what I mean
Go to the full post
Posted 16 November 2014 - 01:44 PM
The issue is that the loop connector on the end of the negative battery cable, with the bolt tightened all the way, is too big for the knob on te actual battery. Any ideas on what I could do to have it tight?
Posted 16 November 2014 - 01:52 PM
photo?
Posted 16 November 2014 - 01:54 PM
Posted 16 November 2014 - 02:02 PM
Buy the correct battery clamp? Shim the negative terminal out for the time being if you really must although this is not ideal
I got one on the way, but for now what can I shim it with?
I got some lead, steel, copper? What would be best?
Posted 16 November 2014 - 02:08 PM Best Answer
Posted 16 November 2014 - 02:28 PM
