Duplex Vs Simplex With Tensioner
6 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 20 November 2014 - 07:42 AM
Hi!
Should a duplex be fitted on a performance engine( 998 cooper head/544 cm)? I currently have a simplex with a tensioner
And where do you guys buy your woodruf keys? Would be handy to have some laying around if I change to duplex, don't want to wait for another week after 'measuring' my cam timing, again IF i change to duplex... Or would the timing be more or less the same as my current ( simplex) setup?
Does anyone know how acurate the minispares standard duplex kits are ? I should time my cam @ 110°.
Edited by Dusky, 20 November 2014 - 07:44 AM.
#2 Spider
  • 15,046 posts
Posted 20 November 2014 - 09:38 AM
For a road going Mini, I always fit a duplex timing chain kit regards of what the engine is. The tensoner though designed for a simplex set up works equally as well with the duplex chain.
I buy my off-set keys from Mini Spares or you could try the veriner set up from Mini Speed, these are quite good, though all of them are a little on the expensive side especially when compared to off-set keys.
I've found the dulex sprockets from Mini Spares as good as originals, they will usually get you within 6 degrees of spec or better, hence then need for the off-set keys.
Again for road going cars, I usually tend to set the Cam Timing about 2 - 4 degrees advanced from that recommended by the cam grinder, this is a personal choice. I do this to make the engine more responsive at lower revs but they do loose out a little at the upper revs.
#3 Ethel
  • 26,029 posts
Posted 20 November 2014 - 10:59 AM
Duplex, no tensioner for me. The tensioner is a tad narrow for the duplex, so bad things could happen when it wears down. There are also low stretch simplex chains now, but I've no experience of them.
#4 Dusky
Dusky
  • 5,322 posts
Posted 20 November 2014 - 02:11 PM
And is the duplex worthwile? What's the difference between my current simplex tensioned with a duplex?
Its to fit on a ( hopefully?!) 60-65 bhp engine :P
#5 jaydee
jaydee
  • 8,565 posts
Posted 20 November 2014 - 02:12 PM
Simplex with iwix chain
Lower weight and no stretch issues.
#6 Spider
  • 15,046 posts
Posted 20 November 2014 - 06:07 PM
Chain stretch, or lack of is only one part of it, the other being spocket wear.
Fair enough, but I have to say, I've never worn one out. My missus car would have done over 200 000 km.
#7 Cooperman
  • 23,319 posts
Posted 20 November 2014 - 10:48 PM
A 998 with a 544 cam will need to be revving to around 6700 rpm to work at its best. These revs are certainly a bit high for a simplex chain and a duplex will stretch at only 50% of the simplex. So for those revs a duplex is really vital.
As for tensioners, it seems a personal choice. I have had experience of 2 duplex set-ups with a tensioner where pad disintegration had either happened or was about to happen. Both were on similar high-revving units (regular use of over 6500 rpm) and on lower revving engines they are probably fine..
As for cam timing, I usually time mine in at 2 degrees advanced from nominal to allow for initial chain stretch and I know many other engine builders who do the same. I once checked and the timing had reduced by 1 degree after 1500 miles, so 2 degs will give best performance between chain replacements.
For the OP, with that cam and thus high revs, the chain and really the engine will need regular stripping and re-building anyway, so it's no real big issue not having a tensioner.
